pau13z
- Dec 23, 2011
- 101
- 2
- 18
- Location
- Sydney, Australia
- VZ Calais 3.6L
Hi all, I know this has been covered a bit before but I have a couple of questions that I think are valid...
I've seen the workshop manual on how to change the water pump, but there are 2 things that I need to know.
1 - When changing the water pump do you need to first drain the cooling system? I assumed you did but people have posted instructions about doing it without draining/bleeding it first.
2 - It's recommended that the cooling system in the Alloytec use the red 50/50 long life coolant. Mine has green coolant in it, which makes me think whoever worked on it last was a gumby. So What I need to know is.. how do I do a full flush?? Now I've seen in posts people have put up the workshop manual pages on how to do this... Basically you need to connect the heater hose outlets together, disconnect the bottom radiator hose and blast water through it until it comes out clear. The real problem though, is that one of the instructions is to remove the thermostat from the thermostat housing to fully accomplish this, and from what I've seen on here nobody has mentioned actually doing that. Now being located at the back of the engine it's obviously not easy to do. Has anyone actually done this? It makes sense, but is it also necessary? I've heard that it's bad to have the 2 types of coolant together in your system so I want to make sure it's completely flushed out...
Cheers guys.
Cheers guys.
