burnz
dah dut dut da dah
- Jun 15, 2005
- 1,373
- 28
- 48
- Location
- springfield
- VFII SS ute M6
P0008 - Engine Position Performance Bank 1
P0009 - Engine Position Performance Bank 2
P0016 - Crankshaft / Intake Camshaft Position Not Plausible Bank 1
P0017 - Crankshaft / Exhaust Camshaft Position Not Plausible Bank 1
P0018 - Crankshaft / Intake Camshaft Position Not Plausible Bank 2
P0019 - Crankshaft / Exhaust Camshaft Position Not Plausible Bank 2
P0112 - Intake Air Temperature Sensor Circuit Low Voltage
P0113 - Intake Air Temperature Sensor Circuit High Voltage
P0117 - Engine Coolant Temperature Sensor Low Voltage
P0118 - Engine Coolant Temperature Sensor High Voltage
P0125 - Insufficient Engine Coolant Temperature for Closed Loop Fuel Control
P0196 - Engine Oil Temperature Sensor Circuit Range / Performance
P0197 - Engine Oil Temperature Sensor Low Voltage
P0198 - Engine Oil Temperature Sensor High Voltage
P0261 - Fuel Injector #1 Short to Ground
P0262 - Fuel Injector #1 Short to Power
P0264 - Fuel Injector #2 Short to Ground
P0265 - Fuel Injector #2 Short to Power
P0267 - Fuel Injector #3 Short to Ground
P0268 - Fuel Injector #3 Short to Power
P0270 - Fuel Injector #4 Short to Ground
PO271 - Fuel Injector #4 Short to Power
PO273 - Fuel Injector #5 Short to Ground
PO274 - Fuel Injector #5 Short to Power
PO276 - Fuel Injector #6 Short to Ground
PO277 - Fuel Injector #6 Short to Power
PO327 - Knock Sensor Bank 1 Circuit low Frequency
PO328 - Knock Sensor Bank 1 Circuit High
PO332 - Knock Sensor Bank :2 Circuit low Frequency
PO333 - Knock Sensor Bank 2 Circuit High Frequency
PO335 - Crankshaft Position Sensor Circuit
PO336 - Crankshaft Position Sensor Signal Range / Performance
PO337 - Crankshaft Position Sensor Circuit low Duty Cycle
PO338 - Crankshaft Position Sensor Circuit High Duty Cycle
PO341 - Camshaft Position Sensor Malfunction
PO342 - Camshaft Position Sensor Voltage low
PO343 - Camshaft Position Sensor Malfunction
PO346 - Camshaft Position Sensor Malfunction
PO347 - Camshaft Position Sensor Voltage low
PO348 - Camshaft Position Sensor Malfunction
PO366 - Camshaft Position Sensor Malfunction
PO367 - Camshaft Position Sensor Voltage low
PO368 - Camshaft Position Sensor Malfunction
PO391 - Camshaft Position Sensor Malfunction
PO392 - Camshaft Position Sensor Voltage Low
PO393 - Camshaft Position Sensor Malfunction
PO443 - Canister Purge Solenoid Circuit Malfunction
PO458 - Canister Purge Solenoid Circuit Low Voltage
PO459 - Canister Purge Solenoid Circuit High Voltage
P0504 - Brake Switch Circuit Malfunction
P0521 - Engine Oil Pressure Sensor Circuit Range /Performance
P0522 - Engine Oil Pressure Sensor Circuit Low Voltage
P0523 - Engine Oil Pressure Sensor Circuit High Voltage
P0560 - ECM Battery Supply Voltage Out of Range
P0562 - ECM Battery Supply Voltage <11 Volts for 5 Seconds
P0563 - ECM Battery Supply Voltage >16 Volts
P0615 - Starter Relay Control Circuit Faulty
P0616 - Starter Relay Control Circuit High Voltage
P0617 - Starter Relay Control Circuit Low Voltage
P0625 - Generator F Terminal Low Voltage
P0626 - Generator F Terminal High Voltage
P0627 - Fuel Pump Relay Malfunction
P0628 - Fuel Pump Relay Malfunction
P0629 - Fuel Pump Relay Malfunction
P0685 - Main (Engine Control) Relay Malfunction
P0686 - Main (Engine Control) Relay Circuit Low Voltage
P0687 - Main (Engine Control) Relay Circuit High Voltage
P1258 - Engine Coolant Over-temperature Protection Mode Active
P1668 - Generator L Terminal Circuit Malfunction
P2105 - ECM Voltage Supply Incorrect
P2227 - Barometric Air Pressure Sensor Range / Performance
P2228 - Barometric Air Pressure Sensor Low Voltage
P2229 - Barometric Air Pressure Sensor High Voltage
P2251 - Oxygen Sensor Signal Changes >10Mv as Heater Control Switches
P2254 - Oxygen Sensor Signal Changes >10Mv as Heater Control Switches
P2500 - Generator L Terminal Circuit Low Voltage
P2501 - Generator L Terminal Circuit High Voltage
