le-jarryd
- Apr 13, 2016
- 2
- 0
- 0
- Location
- Melbourne
- VZ Commodore Acclaim
First off, Hi I'm new here. Driven here through desperation, but here all the same.
Second, yes I have searched for threads on this topic and found a few, I feel that my issue is sufficiently different so here I am with a new thread.
So I've just picked my car up after a service (200k) and after 20-30 minutes of city driving the coolant temperature is sitting at around 106-108 degrees when idling and 102 when driving. When I turned the car off I could hear the coolant bubbling away in the reservoir. I need to know what I should be looking at to fix this, because the water pump is brand new, the head gasket is fine (I specifically asked the mechanic to check it out), I have a new radiator cap, the heater tap was replaced yesterday, the reservoir bottle was changed last year and its not losing any coolant. I re-bled the system twice after pick-up to make sure it was done properly.
The car isn't overheating per se (sitting at just over the 1/4 mark on the temperature gauge in city traffic) but the system isn't pressurized somewhere because the coolant shouldn't be boiling at 102-105 degrees. Could faulty fans be causing this? Could the reservoir cap (the yellow one with the dipstick) need replacing? Thermostat or inlet manifold gasket (I asked my mechanic to check both of these and he said they were fine)?
I might have to give up and take the car to Holden, and then give them all of my money. I guess if anyone knows a really good mechanic who knows their way around a Holden please shout out.
Thanks!
Thanks!
