VZ alternator problem
BigRobL98
VZ Thunder Ute
Having dramas with a VZ SV6. Regulator was buggered, went to holden who replaced the alernator but the charge light and engine light came on after this. Swapped the ECU and the charge light is still coming on after two new altenators and an ECU. Anyon had a similar problem?
Boonz
Donating Member
berri, south australia
green 355 VG ute
dont think you would get 2 dud alternators in a row....
the output of the alternator is computer controlled, if the programming is wrong then the ecu thinks its letting the alternator charge when it really isnt.
BigRobL98
VZ Thunder Ute
Yeah mate but the ecu has been replaced.
BigRobL98
VZ Thunder Ute
Problem has been resolved. 3 faulty alternators caused the problem. Doesn't happen every day. They engine control module was what was replaced.
