VZ audio
garfa
37
SE Victoria
VY SS
ok i think i have stuck my nose in something i assumed would be the same as a vr-vx...
so are these vents in the same place as a V_ series car?
must be a **** (not saying its the worst) place for the imaging.
VQXTC
3rd planet from the Sun...
HSV VP Senator, VY SS Crewman
Tweeters in V series commodores.....
Hey there Garfa, I have been installing tweeters in these models of cars for quite some time now....and i have never come across a set of tweeters that would not fit under the vents just below the windscreen...:p
I found that the best place for tweeters as far as imaging was concerned was to mount them on the A pillar close to the windscreen pointing slightly towards the windscreen, as to how far to point them is a matter of trial and error, depending on the tweeters frequency dispersion....although mounting them in this way doesnt look the best unless you do alot of custom work to integrate them with the interior.
garfa
37
SE Victoria
VY SS
yes i gathered i stuffed up but i still think that for most tweeters it would be a less than ideal place, under the vent that is.
shrapnel
VZ V8 M6 TT
VQXTC, how 'bout sharing that knowledge with me in relation to my question #1? :wave:
garfa
37
SE Victoria
VY SS
there should be some screws there in the vents? and a clip or 2?
cold_carve
Sth East Vic
VE2 SS 6sp Manual
to access "vent" area to modify/install tweeters.
1 if youre say working on the driver side drop the fuse box area (passenger - glovebox)to access 2 screws (all phillips head) holding the side vented trim that sits between the door and the dash unscrew those along with the remaining 3rd screw inside the vent itself and remove trim.
2 with the side vented trim removed you will see toward the top of the dash a screw to remove that retains the top vented trim.
3 with that removed u will notice it will resist comming apart... very cautiously but firmly pry upward the trim - holding it underneith is 4 sprung clips, be very careful not to damage these.
4 you will then see the tweeter 1 phillips head screw to undo that is holding the bracket to the dash with that removed you slightly slide outward along with unclip the plug for removal.
i mounted my tweeters to the bracket once i removed the oem tweeter and ran new cable from that to the crossover.
with the tweeter wired up and installed.... step back thru the steps given n u should be laughin.
please note with the top trim carefully to locate all 4 clips and firmly press into place
VQXTC
Hey there shrapnel, Ok depending on your financial situation and the sort of sound that your after, i would upgrade the speakers first if money is tight a good set of splits 6", or if you still wanted some bass in the front then a good quality set of 6" coaxials, i have used and recommend MTX 3 way coaxials especially off an amp they sound sweet:p ....Or if you can afford it upgrade the speakers and the headunit, you can buy a fascia panel for the headunit that fits very neatly in the dash, then buy some ISO plugs and wire these plugs to your new headunit plug, then you dont have to damage the factory wiring for your factory headunit. Oh and you will also have to buy a European to Australian antenna adaptor as well...Hope this has helped, let me know if u would like anymore help on this....cheers
Lets work as a TEAM and do it MY WAY!! :w00t:
VQXTC
Well dont i feel silly now :bang: I completely went to the top of the thread and anwered that question....(Mental note to self, need to read all responses not just the first one:whistling ) At least u will know what to do when u decide to upgrade the factory headunit....:w00t:
Lets work as a TEAM and do it MY WAY!! :w00t:[/QUOTE]
shrapnel
VZ V8 M6 TT
Excellent, thanks for this. I've looked in a few 'manuals' but none of them actually go through the process. Just in time for weekend! Thanks again.:hit:
shrapnel
VZ V8 M6 TT
Haha no problem. The fact is I've started with speakers as I'm still undecided about the head unit, leave it stock and get the phreddy's line-in + amp done or go with a new one, the new JVC KD-AVX2 is so tempting as I also need to buy an mp3 player as well and it wouldn't bother me burning mp3 DVDs... and if I could get a hold of the european version (plays DIVX)...:driving:
