vz battery terminal problems maybe
glenny1988
VZ v6 Executive alloytech 04
hi all...started car the other day just clicked than lost all display and power,noticed negative terminal on battery was loose,its tight as tight can be and keeps slipping off causing not to start,bought universal terminals wont fit anyone had to change em? if so what types do u reccomend and is it a hard job to replace?
cheers
zedda
Vic.
vz exe.
Why won't the new terminals fit? They can be gently prised apart a few mm if too tight or hammered tighter if too loose. Have a good look at the old ones first & see if something can be improvised, otherwise change to the new ones, easy job.
PRAVX II S
Australia
Commodore
Make sure you clean the terminals on the battery with a wire brush or battery terminal cleaner.
For good connection.
After you have installed the new terminals
