bushute
Hey @figjam, I want to try and explain the mechanics as requested. I hope others find it useful too.I would like the logical mechanics and physics of a scrivet explained.
To get a scrivet out you unscrew them in the normal way, that is, by applying downward pressure into the head of the scrivet with a screwdriver..
By applying downward pressure, that defeats the unscrewing, as the threads are so fine and plastic, nothing happens.
The engineer who designed these, and the bean counter who insisted they be used, should have been sentenced to 'unscrewing' 1,000,000 of these each whilst blindfolded in 35* heat and 5* cold on alternate days..
'By applying downward pressure' and 'screw them in the normal way' - that's usually the problem. People apply too much pressure and treat it like a regular screw. They strip it as soon as they force a screwdriver down on the head and try and reverse it out. You need only apply just enough pressure to engage the driver head in the seat. A scrivet is not a high torque fastener. No plastic fastener is. Don't treat it as a regular screw.
When we (you and me) unscrew a regular screw the usual approach is to push down (usually firmly) on the fastener and twist. We need to overcome the torque that's been applied to the screw on tightening by engaging the driver head hard enough - which can be approx 5-10Nm for a metal screw (hand tightened). A scrivet has a tightening torque (from my research) <= 1 Nm.
Applying a similar pressure to a scrivet, as you would a normal screw, deforms the threads, causing the screw to spin and not back out. That's when one has to lever it out.
I screw/unscrew scrivets using a hex driver bit (like used in a drill driver) using my fingers. Works great, gets into small spaces and doesn't strip the thread. It can apply enough torque to expand the fastener shaft and be removed without stripping. It does work. Need a bit more grip? Wrap some electrical tape around the driver bit shaft (which is what I do). Also, using a small stubby driver with light pressure works well too.
Hope that helps. If not, all good, go with an alternative - sometimes scrivets just screw us over (no pun intended), and we curse to the gods and find an alternative.
