VZ Berlina Station Wagon
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by Rod 1, Sep 29, 2011.
  1. Rod 1
    Rod 1 New Member
    Sydney, AUS
    How do I remove the circular light switch assembly on the dashboard so I can replace the small globe?
  2. Rod 1
    Rod 1 New Member
    Sydney, AUS
    There are two small metal clips at each side that require depressing to remove the switch. They are located at 3 o'clock & at 9 o'clock & should be levered inwards towards the switch itself. I went to an auto electrician & found the answer myself.
