VZ clutch..anything else?
2005vzute
Djabringyagrogalong
Glenfield 2167
forums.justcommodores.com.au
2005 VZ Ute M6
g'day all,
so i've just bought a heavy duty clutch set up for my v6 ute...the kit has the solid flywheel, new slave cylinder, new pressure plate and new clutch plate...also got new flywheel and pressure plate bolts...is there anything else i should be replacing?. is there a spigot bearing or bush i should be worrying about..its only got 82,000 on the clock and its a 05 model..if anyone could think of anything else to go with it could you's please let me know
cheers everyone
ashbox
back in black
The Car
something black
yeah i'd prob replace the spigot bearing to, i know the clutch kit i bought for my vx cam with everything apart from pressure plate bolts so i'm surprised u didn't get a flywheel and spigot bearing
lein
Comrade Commodore
Tropical QLD
VC 202/4sp
There's no spigot in the rear of the alloytec from memory. The reason I remember is because it's so odd. Either that or my VZ didn't have one and I should have fitted one. :)
2005vzute
Djabringyagrogalong
Glenfield 2167
2005 VZ Ute M6
it should..the guy done a dodgy one me but..i asked him thrice for an extreme clutch kit and he said he has it and its in stock..then at the counter he gives me pbr telling me its the same ****, which it probably is...except with a lot more ####ing around...i got the pbr anyways because i need it in a rush..i think the spigot should still be alright..its only had 82,000 on it so should be good
Filthy_Phil
VS II S Ute
check your thrust bearing for signs of clutch dust, if that goes u r screwed, regrease it too if u can
