alloytec sludge
not sure what to do i see justcommodorespares has them for 200
Ahhh, sorry to hear you have the infamous VZ ecu failure. Its a real pain in the ass.not sure what to do i see justcommodorespares has them for 200
Prior to performing the linking procedure, obtain the security code and BCM security number. For further
information, refer to Vehicle Security Card.
2 Connect Tech 2 to the data link connector (DLC).
3 On Tech 2 select: Body / Powertrain Interface Module / Security / BCM Link to ECM / PIM.
4 When Tech 2 displays BCM Replaced, press the No soft key.
5 When Tech 2 displays PIM / ECM Replaced?, press the Yes soft key.
6 When Tech 2 displays Select Engine Type use the up and down arrow selection keys to select the appropriate
engine type and then press the Enter key.
7 When Tech 2 displays Please Select, use the up and down arrow selection keys to select PIM Replaced, and then
8 When Tech 2 displays BCM Security No., enter the BCM security number, press the Enter key.
9 When Tech 2 displays Turn Ignition Off!, turn the ignition switch off.
10 When Tech 2 displays Turn Ignition On, turn the ignition switch on.
11 When Tech 2 displays Enter Security Code, enter the security code and press the Enter key and then the Okay
soft key.
12 When Tech 2 displays Confirm Security Code, re-enter the security code, press the Enter key and then the Okay
soft key.
13 When Tech 2 displays Stop Engine – Turn Off Ignition, turn the ignition switch off.
14 When Tech 2 displays Turn Ignition On, turn the ignition switch on.
15 When Tech 2 displays Programming Successful, press the Confirm soft key to return to the Tech 2 Security
screen.
Glad to help. Make sure to post back if you have issues/success so others know what to do.thanks for that . that sets it straight
I bought a new bcm to replace in my VZ ute , got said new bcm .
And tryed to link it with a holden tech 2 but it said the bcm was "locked" and that I needed the secuirty code to proceed , but to get the security key i need to know the security key to access that menu lol .
So no way to get the old code off the new bcm and the wreckers have no idea what car it came from (for the vin etc ) .
Have you found anyway to reset the bcm ?
Which security code do you mean? The BCM security code, or the IMMO (Immobilizer) code?
BCM should be 6digit code (I think from memory) and the IMMO is 4 digit code
Yeah the 6 digit one , cant access the code reset part on the tech 2 without knowing the 6 digit code to reset the code that we dont have lol
