VZ Commodore (Change Steering Wheel)
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by NO_Idea64, Feb 15, 2007.
  1. NO_Idea64
    NO_Idea64 New Member
    VZ 3.6L Executive
    Gday,
    Can someone help with a step by step guide on how to change my steering wheel. Bought a geniune commodore leather steering wheel but lm told l need a special tool to remove airbag. What is this tool called and where l can l purchase it in Melbourne. I know about removing the airbag fuse. Please be clear with instructions cos im a noob at doing this stuff. Any advice is most welcomed.
    Thanks, Bill:) :) :)
  2. Aggro_VE
    Aggro_VE The Overseer
    Lake Macquarie
    A lazy VE
    I just recently had my wheel off, mind you Phreddy did it, forget the procedure fire a PM off to him, he be happy to help you out, I put in a pic when airbag section is removed, looks like a torx type headnut, if you have one the right size, undo then pull wheel off :)
  3. commodore2004
    commodore2004 New Member
    vz berlina
    If your doing a vz
    You need a very thin bladed flat screwdriver, at the back of the wheel there 4 slots you have to push the clips back inside to release the airbag, be very careful as the bag will spring off when you release the last clip keep one hand on the airbag at all times.
    Once you have released the airbag just clip off the yellow wire from the steering wheel.
  4. NO_Idea64
    VZ 3.6L Executive
    Thanks Guys:) :) :)
  5. Bouncing Castle
    Bouncing Castle New Member
    VIC
    VZ Executive
    I have done this to my VZ.. pretty easy procedure
    As a good rule of thumb you should take out the airbag fuse (just so you don't have the airbag exploding in your face)....
    Cheers,
    Chris
  6. dan-0
    dan-0 New Member
    06 VZ SS 6.0Ltr
    I installed a leather steering wheel on my VZ a while ago. I had problems tho. It took me hours to fugure out how to fix the problem.
    IF ANYONE INSTALLS THEIR NEW STEERING WHEEL AND IT IS NOT ALIGNED, EMAIL or PM ME...
  7. unregistered
    unregistered New Member
    03 VY V6 S2
    why dont you just tell us?
  8. markovr
    markovr Well-Known Member
    northside brisbane
    07vessv 94vr .04vz wgn,93vp wgn,82 vhV6 wgn 88 vn
    secret squirrel....I must have arsed mine cause I had no problems after I worked out how to take the airbag off
  9. dan-0
    dan-0 New Member
    06 VZ SS 6.0Ltr
    The way I type it will take me another hour.
  10. dan-0
    dan-0 New Member
    06 VZ SS 6.0Ltr
    Hey guys
    I took my air bag off, tinkered around with the steering wheel again and now Im getting a 'SRS air bag fault' when the car starts up. My sterring wheel radio controls are also not working?? I checked that all was plugged in again.
    Any ideas?
  11. The Windsurfing VY Wagon
    The Windsurfing VY Wagon New Member
    Cairns, QLD
    VY S2 04 S/W
    Did you disconnect the batt?
    If not that will be where the problem lies with the Airbag fault and that means a trip to your local Holden dealer so they can Tech II it at around $45.00.
    Radio Controls? not to sure really, a fuse, a loose connection, pinched wire or some thing to do with the airbag as well as they both come off the steering wheel? No idea is what I am trying to say but I do know that the steering wheel radio controls are a bit hopless at times, working then not working then working again and I have heard heaps of them doing this.
    Hope this helps
    Windsurfing.....
  12. dan-0
    dan-0 New Member
    06 VZ SS 6.0Ltr
    Your right.
    The only time I did NOT disconect the battery I started getting this warning!
    Can Holden Tech II do anything else to my car? ie tune it to match my zorts mods?
  13. Kung-Foo-Kamel
    Kung-Foo-Kamel New Member
    Rockingham
    Custom Hilux with a V6 Ecotec
    SRS fault can be reset by any workshop that has a scan tool like the snap-on one
    I do them time to time, so you dont need to go to holden, just ring places like MIDAS, Autobahn, Automasters.......
  14. dan-0
    dan-0 New Member
    06 VZ SS 6.0Ltr
    Thanks for the info mate, I try and avoud GMH like the plague
