Could be thru the door as said above but also windscreen. Cars are surprisingly flexible and can move enough to disturb the glue.
Pull the A-pillar cover off, remove the grab handle, pop the screw cover off the B-pillar cover and remove that screw to aid assembly. Grab the cover with your hands and pull towards the Center of car. It may not be coming in here but for 5-10 mins work you can eliminate that. To fix you would just wipe a small amount of urethane from the outside after pulling up a small section of the windscreen mould. The urethane also holds the rubber mould in place so fit that back before it cures.
Pulling the kick panel off will eliminate a couple more locations too. Just hope it’s not from a rust hole under the plenum cover. Which would be visible running down the firewall as stated in the first reply
