Dutch
- Oct 3, 2017
- 6
- 0
- 1
- Age
- 58
- Location
- Perth WA
- VZ Commodore Acclaim
I have a VZ Commodore that suddenly threw an ABS, ESC and Cruise Control fault. The Cruise Control will not engage and the ABS warning and ESC warning on LCD dashboard. I put the TECH2 on the beasty and the only fault code showing was C0161 "Stop Light Control Circuit Problem". The weird thing is that the stop lights work fine. The fuses are fine and the globes all work.
I thought that it might be one of the 2 x foot brake switches under the dashboard (because there are two switches on the foot brake) so I went to the wreckers and after a lot of stuffing around got two replacement switches. I then retested for trouble codes and was disappointed with it throwing the same warming ABS Fault and Electronic Stability Control Warning on the LCD dash. C-0161 still showing up.
Even though it was saying "stop light circuit fault" I thought that it might be the Bosch ABS electronic module that bit the dust. So after another trip down to the wreckers and I came back with a replacement $100 ABS module (one with Electronic Stability Control) with the matching Bosch part number. After testing the replacement ABS module...... yep! Bloody C-0161 code persisted.
I'm kind of at my wits end with this problem. Any ideas as to what else I can try?
