VZ crewman engine identification
Alant
62
VZ Crewman
hi gang, I have a 3/2007 VZ crewman v6 LE0 engine. I’m told that is a VE engine, but I’m trying to get a positive ID on the engine type so I can get correct servicing specs. I have looked through a bunch of threads but can’t find and engine number / ID info, can any one help.
Fu Manchu
WA.
Not sure what might be meant by VE engine.
You have the same engines, they do have different wiring looms and computers running them.
The VE was produced from 2005 and the Crewman, ute and VZ Wagons kept in production until a year or two after the VE went into production.
I have one of the last VZ Crewmans made. A mid '07.
LE0 is LE0.
The stuff bolted onto it differs.
Alant
62
VZ Crewman
Thanks for replying, Yes mine is one of the last ones as well Build 03/2007. It now has 220,000 kms and has pretty much behaved without fault all that time, so i'm guessing the cam chain is not one of the dodgy ones. I was really just looking to better identify the engine for service specifications.
Fu Manchu
WA.
Your best bet is to source a factory manual in pdf format.
gungazza
67
west suburbs
executive vt 5.0lt VZ CREWMAN
there is a thred here somewhere that tells the engine numbers that are a cam chain problem
gungazza
67
west suburbs
I have a 06 leo
