VZ Executive Auto Fuel Consuption 13-15L/100km
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by dingdong555, Jul 25, 2011.
  1. dingdong555
    dingdong555 New Member
    Perth, WA
    VZ 2005 Executive
    Hi all.
    Got a VZ Executive auto which has "POWER" mode off and is being driven like any normal car, to give you an idea it shifts up at around 2000-3000rpm, no higher than that.
    However, my fuel consumption is NEVER below 13L/100km, I find this extremely hard to believe, so I reset the ECU (disconnected battery) and still get roughly the same. I've also had a service in the last 500km.
    Any ideas why? My folks VE SS Manual gets around 14L/100km and gets driven pretty hard.
  2. redvs2
    redvs2 New Member
    Raptor charged Vs, VY ss ute, rodeo daily
  3. aaronevolution
    aaronevolution Donating Member
    Hastings, Victoria
    TURISMO VZ SS 6.0
    I get better economy out of my vz 6 spd SS 6 Litre than I did in my vy v6 and my VR v6.
  4. dingdong555
    Perth, WA
    VZ 2005 Executive
    Yeap, all up to date with the log books.
  5. heyitsEnricoPallazzo
    heyitsEnricoPallazzo Big block Alloytec
    VZ A4 Saloon
  6. doms1
    doms1 New Member
    BANNED
    Yep our vz exex alloytec gets those sort of figures,pos of a thing
  7. jd hot stuff
    jd hot stuff 355 power
    Melbourne VIC
    VB SL 355 stroker, VZ V6
    Funny how i just got 9.9L per 100km and my avg is no worse then 10.6L per 100km
  8. CAPRILICIOUS WL
    CAPRILICIOUS WL New Member
    WL CAPRICE
    Could be ur oxy sensors.
    What petrol do u use?
    I just did my oxy sensors and it dropped from 18l/100km to 15l/100km @ an avg speed of 35km/h.
  9. vz_sv6_owner1990
    vz_sv6_owner1990 New Member
    South Sydney(the shire)
    VF SS storm ute
    Which lambda/Oxygen sensors did you change. All 4 Or just fronts or rears??
  10. CAPRILICIOUS WL
    WL CAPRICE
    I just changed the front two sensors before the cats.
    Do u know what the rears are good for? Do u reckon I should change the rears aswell?
  11. vz_sv6_owner1990
    VF SS storm ute
    It pretty much does the same thing as the fronts but it measeures your exhaust gasses after the cat converter to see how much is getting trapped by the cat. And measures the fuel mixture to ensure no harmful gasses go out the exhaust... I'm prettY sure
  12. CAPRILICIOUS WL
    WL CAPRICE
    So do you reckon it will have anything to do with the performance of the car? The rear oxy sensors that is.
    I feel like my car is really sluggish but I dont know if it's just me. Lol
    But then again it's a 2ton + car.
  13. aaronevolution
    Hastings, Victoria
    TURISMO VZ SS 6.0
    2ton+? WL Caprice's weigh under 1800?
  14. CAPRILICIOUS WL
    WL CAPRICE
    Not mine. Lol
    20" Rims+Tyres x 4 = 125kg
    70L LPG gas tank full = 100kg*
    75L petrol tank full = 90kg*
    2 x subs n amp = near 40-50kg*
    Me x1 500kg. Lol 80kg.
    * = rough figures.
    Total = Turtle. :p
  15. imoore
    imoore New Member
    2014 VF SSV ute
    the after cat o2 sensors are only there to monitor the cat efficiency. i believe the front ones are what make a real difference to fuel con and performance. My vz ute averages between 12.5 -13.
  16. vz_sv6_owner1990
    VF SS storm ute
    @caprilicious honestly they shouldn't be used for performance or fuel consumption at all im pretty sure they are only used to see how much stuff is going through the cats for EURO 4 emissions laws
    My advice would be to take them out and check to see if the tips are dirty.. If they look ok then leave it
    As I said I'm pretty sure they are only there to comply with EURO 4 emissions laws.
    Ps I'm only a 3rd year apprentice mechanic so I may be wrong
  17. Danoz
    Danoz New Member
    Sydney, NSW
    VZ 06 Exec
    Post your avg speed when posting your fuel consumption!
  18. vz_sv6_owner1990
    VF SS storm ute
    I get average 15L/100km at 30km/h in my sv6 which I know is ####ed
  19. CAPRILICIOUS WL
    WL CAPRICE
    Thats exactly what mine is sitting at atm.
  20. boogervz
    boogervz New Member
    NZ
    VZ Exec Wagon V6
    My VZ Wagon Exec does 11.5-12L/100km around 40-45km average speed..
