AussieDave
- Jun 1, 2017
- 5
- 0
- 1
- Location
- Mandurah
- Commodore VZ 3.6 Alloytech
Hi all. I'm hoping someone can help me out. Since my last coolant change I've noticed that I've been loosing coolant after driving it around and it seems to be getting worse. At the moment I'm loosing about 500ml of coolant each day and I don't drive far in it.
I had a good look today and the leak is on the right hand passenger side underneath. There's some coolant on the base of the overflow tank and it seems to be spraying back from there on the passenger side tire and next to it only underneath. there's some spots of coolant on the ground underneath the overflow tank. The overflow tank is now over full going by the dipstick gauge. I've noticed that my temperature gauge isn't as high as what it usually is which usually sits on the quarter mark of the temperature gauge or just over when it's really hot outside. I've been checking the thermo radiator fans when I get home and keep the engine running and they seem to have stopped working.
I've tested both fans with an external 12 volt battery and they both work fine.
I've gone in to the dash menu system and the instrument temperature says 41 degrees and the coolant temperature says 72 degrees.
The low gauge temp has only started since my last coolant change and I suspect I'm having the same issue with my other VZ wagon too when I changed the coolant last. I've never had this issue before when changing coolant and strange it's happened to both of my VZ's at the same time, the coolant temp say 92 degrees. I replaced the coolant temp sensor in the wagon but the gauge temp is still low but that hasn't started leaking yet and only need to put a small amount of coolant in the wagon every couple of weeks.
I'd say it's just overheating but could anyone explain why the temp gauge is low and where the problem could be?
