bigdaddycool
- Sep 5, 2008
- 515
- 11
- 18
- Location
- Brisbane, Queensland
- 2009 VE SS SILVER SEDAN
For those who know about our 2005 VZ Executive project we've been working on here. We have a 2005 VZ Executive which was involved in a accident prior to purchasing it (front on collision under a truck)
We've been restoring it, during the process we were plauged with a Fuel Guage Error issue preventing the car from starting, having to short the starter relay to jump it. We messed around for along time with the ECU via VCM Suite to track down what was causing the immobiliser to be set off when it would not start.
We tried disabling different sections of the immobilisers checking system, starter relay DTC's etc with success only to have the problem return a few weeks later.
The accident the car was involved in evidently broke one of the clips off the ECU (botton clip out of the two) on the front of the engine. We ended up replacing the whole wiring system thru the engine bay which did not have success. After much reading on the forums, people mention to check earths, possibly cluster and BCM's etc, the fuel sender..... which wasn't really conclusive.
In the end after trialing a few auto electrictions, mobile mechanics we found a guy who managed to track down the issue for us.
*** The ECU was infact damaged, obviously the radiator hit it breaking the clip and damaged either the pins, traced or something internal.
The starter relay was shorting as the ECU earth for it wasn't working.......
$1650 later........ a new ecu has been fitted, software update and tuned. (included pickup/delivery as it had to be towed)
If you suffer from a similar problem, a short solution I could suggest is to possibly re-route the earth off the starter relay to the car chassy...... as a short term solution to try. Otherwise as most know u can jump the car with the AC on, a cheaper solution is to put in a Engine Start switch in the dash that shorts the Starter Relay when the AC is on.
( I just thought I would share our 6 month drama's solution with you guys ). Alot of people have done fuel sender calibrations, got new bcm's etc......... new clusters....... only not to have it fixed.
I'll grab the details of the guy who fixed it for us and post it up later if anyone wishes to know.
PS. Since we only just got the car back, i'll confirm in a few weeks if the cars still going perfectly.
