Vz intake insulator...
Discussion in 'Mace Engineering' started by MattMarkey, May 8, 2011.
  1. NAVZCALAIS
    NAVZCALAIS New Member
    Wodonga
    VZ Calais 3.6, 1980 WB Tonner
    Hey guys just on the topic on mainfold insulators. As far a i'm aware you can't run the insulator with the CPR6 mainfold? When i got both of mine i had already modified my bonnet a bit so it would fit. I'm just wondering is it possible to fit both in withour alterations to the bonnet?
  2. MACE
    MACE Well-Known Member
    Ah excellent frank6969 :D
    Glad to hear you're happy with the product.
    On the VEs it is from my understanding, if anything it helps a little with the installation process. Though it can rub up against the plastic cowl on the back of the firewall, but apparently it's not a problem.
    VZs on the other hand can struggle with the CPR6 by themselves, so I dare to run both, the bonnet will need to be modified
    Cheers,
    Steve
  3. Skidskidbangbang93
    Skidskidbangbang93 New Member
    Vz vl
    Hey there Steve I've gotta do my filler neck. So thought I may aswell do the insulator at the same time. Is it possible to go straight to the 12mm on a dead stock vz?
  4. MACE
    Hi Skidskidbangbang93,
    Thank you for your enquiry.
    "I've gotta do my filler neck. So thought I may aswell do the insulator at the same time. Is it possible to go straight to the 12mm on a dead stock vz?"
    Sorry for the delay in getting back to you. We always recommend taking some measurements to be 100% sure. however, from experience, the 12mm manifold insulator would fit your vehicle. MI603 is the part number for the 12mm insulator from the following.
    https://www.maceengineering.com.au/epages/shop.sf/en_AU/?ObjectID=1469404
    This kit comes with everything required for installation. Fitting instructions can be shown below.
    https://www.maceengineering.com.au/.../C0A8/D240/2EA6/ALLOYTEC_MI_INSTALLATION_.pdf
    If you have any other questions, please do not hesitate to ask.
    Kind regards,
    Michael
  5. Skidskidbangbang93
    Vz vl
    Cheers for that I ordered one when I wrote the comment, I'll make it fit. Cheers for the reply.
  6. MACE
    Awesome, thank you for letting us know.
    Please keep us posted.
    Best regards,
    Michael
  7. Skidskidbangbang93
    Vz vl
    Got into a bit of a chase and the car was pushed off the road. The parts arrived today haha spewin! Cheers anyway
  8. commodore665
    commodore665 expat Saffa
    New Zealand via Cape Town
    2005 SV6 & Alfa Romeo 156 V6
    you were pushed off the road , I see ......................................................
