Hi All
To conclude this 7 month adventure - the beast lives! Despite the diagnostics pointing towards the TACM it wasn't. It was a faulty cable from the TACM to the accelerator pedal.
The cable arrived by post today - I was late home from work but just had to plug it in just in case. Sure as eggs the beast started and ran - sort of properly for the first time. I was amazed.
If you have followed this thread you will know that the cable had been cut and shut using a new connector that had been pinned as per the manual. As the manual's pin diagram was incorrect for the connector for 6 and 1/2 months I was unable to get the correct readings and the pedals I had purchased all seemed to be incorrect; because of course I was trying to align the readings from the pedals to what the manual indicated. So all of my musings did not make sense. Thanks to
@Fu Manchu I was able to determine that the pinout in the manual did not match the pins running into his pedal - which was the same pedal I was using.
When I changed the pins to match I was able to finally get consistent DTC readings indicating that the accelerator pedal system was not well despite the cable now "functioning". Each individual cable had been tested, on numerous occasions, for continuity and pin to pin location. At my wits end I decided to replace the cable and the TACM. Replacing the cable, $135 from LSXtreme, has resolved the problem.
I checked the new and existing cables - pins in identical locations. All the joints were soldered and covered with heat shrink. I can only surmise that there was a dry joint in one of the cables that led to the out of range readings being thrown. The lesson to be learned here is - when working with computers do not cut and shut the loom. If you need to repair the loom run new cables from point to point and replace the connectors at both ends. Had I taken this approach - or purchased the cable from LSXtreme at the same time I purchased the ECM I would have been on the road about six months ago.
However, as a result of this trauma:
I now have a Tech 2 scan tool that is a real treat when working with the VZ,
I have managed to download a workshop manual - albeit with one incorrect diagram - thanks to
@Fu Manchu,
I know a **** tin more about how the LS1 and drive by wire systems work than I ever did;
What I have found regarding pedal numbers, resistance readings and the dreaded incorrect B22 connector diagram is now documented.
I have learned a valuable lesson on computer based cars - should have stuck with FC's, and
I found this site which is just a brilliant resource.
I trust that sometime down the track that my experience will help someone else solve a problem.
Cheers n Beers
Jolls
