VZ LS1 Engine Temp (thinks its overheating)
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by Kiwifolk, Feb 3, 2019.
  1. Kiwifolk
    Kiwifolk New Member
    Bay of Plenty, New Zealand
    VZ Calais 5.7
    Hi all, ive had a search through and couldn't find someone with the same issue.
    When driving a short distance (under 10min) say to the shops and back.
    When I turn the car back on at the shops it is telling me the temp is 126deg.
    Obviously this isn't the case on such a short drive.
    Engine is still cool to touch and can open the radiator cap still.
    Longer trips with It intermittently jumping to full and back to normal has the motor physically getting up to temp etc but the gauge still playing up.
    Would this be a faulty sensor and if so which one would I be best to look at first?
    My understanding is the LS1 has more than one sensor it reads off?
    (car is a late 2004 VZ LS1 Calais)
  2. 07GTS
    07GTS Well-Known Member
    Australia
    VEGTS BLOWN E85
    prob just the coolant temp sensor playing up pretty cheap to replace, only the one temp sensor for the ecu and then off to the dash use same data, passenger head at the front 2 wire
    Tonner Matt and Kiwifolk like this.
  3. Kiwifolk
    Kiwifolk New Member
    VZ Calais 5.7
    Thanks! That’s what I was hoping. I’ll get one in order tomorrow and we’ll find out!
  4. Kiwifolk
    Kiwifolk New Member
    VZ Calais 5.7
    Well my new part arrived and I have now installed it.
    Had to re-wire for a new plug and the old wiring was pretty messy so tidied that up.
    All seems well so far.
