VZ LS1 problem
Jolls
Murrumbateman
VZ SS Ute
Hi All,
I am in the process of taking the LS1 from my old VY and throwing it into a VZ LS1 ute shell. We have livened her up between bodies with a new cam and a few other go fast bits. We can get the old girl to start and idle but it will not accept input from the accelerator - drive by wire. When we got the shell it was missing the accelerator pedal and ECU. I purchased an unlocked ECU from LSXtreme but just can't seem to get the pedal and throttle body to communicate. Besides going back to a VY loom and cable clutch is there a way to fit an aftermarket pedal and throttle controller to bypass the TAC or is the link critical; ie, is the TAC output also fed into the ECU?
Cheers n Beers
Jolls
Tonner Matt
Darwin
VZ 1 Tonner LS1 M6
Not sure if this will help or not because I'm no electronics guru, but as far as I know the VZ LS1 pedals were a stand alone part for the specific VZ LS1 powered vehicles only
The VZ LS2, L76 & L98 powered vehicle pedals will not work with the LS1 vehicles and vice versa
If you've fitted the VZ LS1's electronic throttle body, in theory you'd expect them to communicate..........
I presume the VZ's shell still had the factory harness fitted to it when you purchased it
The other problem nowadays is finding an electronic throttle pedal for sale, because they are no longer available through Holden and second hand units are getting pretty scarce
I actually bought 2 sports pedals a few years ago for my 1 Tonner, and I paid a ridiculous price for them because of that reason
EDIT:
Just out of curiousity, what is the part number of the pedal you are using ?
I want to compare it to my factory original pedal, and the sports pedals that I have currently
Jolls
Murrumbateman
VZ SS Ute
Thanks Matt,
Answers to all below
That is 100% correct. The accelerator pedal only works for a VZ LS1 (or
Yes mate the harness is complete, though I am wondering if the TAC Module is the problem. The throttle body appears to run though its learn procedure so I am expecting the fault is not on that side of it.
EDIT:
I have secured two pedals from two separate wreckers both advising that they are off an LS1 powered VZ. The part number is 92183447. As indicated in the other post this is not the part number Holden have for it; however, they advise me that it is off an LS1 powered vehicle. Maybe a Stato. Both are sports pedal and both supposedly came off VZ SS LS1s.
Jolls
Tonner Matt
Darwin
VZ 1 Tonner LS1 M6
Jolls
I'll check the Part Numbers on mine for reference and I will get back to you
I still have my original factory pedal (non sports style) and I do remember that the last three digits of the part number were sequential with the sports style pedal
Something along the lines of ####199 & ####200
Beedle
51
New Zealand
Vz calais v8
I have a vz Calais with the same problem, sourced a replacement and ended up with the 6.0 litre one which as you know doesn't work. Am currently looking for 1 with the same part number as my original which is 92210499
