Yiffington
- Oct 16, 2018
- 2
- 0
- 1
- Age
- 27
- Location
- Perth
- VZ 5.7 SV8
Hey guys I'm on my last straw here I've tried every trick I can think of to fix this damn cruise control. I've got a VZ SV8 manual and the cruise enabled but wont set. Sometimes the set will flash on and then off when you try and set it but generally nothing happens. I've tried cruise diagnostics and it says apply the brake before attempting to enable cruise. Basically what I need to know is which of the two brake switches is for the cruise control? The one with the single 4pin connection or the one with 2 2pin connections? Also my car only has one plug going to the switch with 2x 2pin connectors...
Tldr: Which switch is which on a vz with cruise control!
Also sorry if this is in the wrong location, this forum has a funny organization system.
