vz power mirror plug
markovr
62
northside brisbane
youtu.be
07vessv 94vr .04vz wgn,93vp wgn,82 vhV6 wgn 88 vn
Had a problem with my vz right hand power mirror not working ...tracked it down to the mirror but I did a diagram of where all the wires go on the door switch plug so it might be easier to test without taking the whole car apart to fix.
With switch removed and unplugged on door plug
With a multimeter on volts you should get 12v with one lead on the pink wire and the other on the black wire with the ign switch on
Then with multimeter on ohms you should get 60 odd ohms across light blue to brown wires and also 60 odd ohms on yellow to brown wires to prove circuit on driver side mirror
and 60 odd ohms grey to brown wires and 60 odd ohms on violet to brown wires to prove circuit on passenger side mirror
You can use a paper clip to make contact with the top lugs in the plug for testing
