Vz rattle at cold start
vCoffeecup
21
Vz sv6
I have a 05 vz Sv6 and every time I start the car in the morning it has and extremely bad sounding rattle which cause the engine to shake and almost break down, and lasts for about 10 seconds, after that the car runs fine, any ideas?
vCoffeecup
21
Vz sv6
Penrite semi synthetic 10W-40
scaredyet
40
Mosman
Holden VZ Lumina Wagon
Could be a vacuum leak. Check the elbow hose at the front of the manifold. Then again it shouldn't be fine after not starting properly
vCoffeecup
21
Vz sv6
I also thought that could of been the problem as it had a split in it, but I replaced it and still have the issue
99notout
VZ Equip Wagon
Try 5W-30 and see if it helps, you could have sludging and the thinner (correct) weight oil will flow quicker, and a new filter. Always try the easiest first.
vCoffeecup
21
Vz sv6
I’ve put in 5w30 and the Sound seems to have stopped, thanks for everyone’s help
