Davidde69
- Oct 12, 2015
- 4
- 1
- 1
- Location
- New Zealand
- 05 VZ SS Crewman
Hi all, great to be here and hoping to be able to contribute in some small way eventually.
I am having some issues with the RH rear brake on my 05 VZ SS crewman specifically the outer pad keeps wearing into the caliper bridge, dropping down and starts wearing into the handbrake drum section of the rotor.
I have already replaced the rear pads, caliper bridge and rear rotors twice because of this, I tend to get somewhere between 20K to 30K before a squeek like glazed discs starts and then the damage is already done.
This is only happening on the RH side rear, all the others are good.
Have added some photos: 1 to 3 RH bridge at 22K showing the wear, 4 LH bridge at 180532 KM - very minimal wear, 5 RH rear rotor showing the wear mark.
Has anyone heard of this before.
Thanks
Dutchy
Update - found out that the car had been hit in the RH rear early in its life before i purchased it, problem turned out to be a bent RHR axle, have replaced this with a new 1 and no more problems, hope this helps.
cheers
Thanks
Dutchy
cheers
