exanVZ
- Feb 20, 2011
- 325
- 115
- 43
- Location
- Perth
- VZ Thunder
Well I changed it over and screwed on as tight as I could (hand tight is ok yea?) but still running hot. I will let it cool right down before giving it a second chance, current perth temp still 34-35c.
I removed the old cap while the engine was still quite hot (but not too hot) and noticed the coolant was almost level with the bottom of the neck where the cap screws on (full!) and then I checked the overflow (coolant checker thing passenger side) which was almost double the 'max' level on the dipstick so could it be that there is now too much coolant? I added 2L recently when the problems started without really knowing what I was doing, could it mixed brands (I used tectaloy heavy duty 90+)? Is there an easy way to drain some out (if there is such a thing as too much) so that I can test it with regular levels?
Temps are still getting hot, over 120c (turned on diagnostic to test) but within a minute of turning on the hot air it drops to 112-115ish (3/4 between C & H) where it will sit as long as the hot air is on. Seems to me it is just getting a little too hot.
If it was a thermo getting stuck, temps wouldnt behave so consistently (i think...) and there are no leaks visible and not a drop has hit my carport since I bought this car (7 months+) so I am pretty sure that it can't be a leak either. Again oil is okay too (that I do know how to check).
Any suggestions before forking out to get this looked at? Seriously can't afford that right now. Really appreciate the advice everyone, keep it coming!
As a last alternative, anyone who knows what they're doing wanna take a look for a carton or mates rates or something?
Cheers,
Patrick
Cheers,
Patrick
