Vz squeal
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by Uss285, Jul 26, 2012.
  1. Uss285
    Uss285 New Member
    Mandurah
    Vz thunder
    I got a constant squeal when the car is warm or cold ive replaced the pulleys and belts the noise gets a lil louder when u use the A/C but that belt has been changed also. Any suggestions? Its only been a couple days since ive changed them over dno if they got to be worn in?
  2. Uss285
    Uss285 New Member
    Mandurah
    Vz thunder
    It also gets louder as the revs go higher
  3. morphix
    morphix Member
    Cardiff, NSW
    2004 VZ SV6 5-Speed Auto
    Wondering if its one of the accessories running off the main belt, the pulley squeaking? Eg. alternator or so?
    I also have a similar thing too, except mine usually cannot be heard after driving for a while, but it sounds terrible when coasting or going slow in streets or car parks :(
    I need sometime to diagnose it more, i'll keep watching this thread also.
  4. Sabbath'
    Sabbath' Redblock Jesus
    80 Series// MK5 GTi//
    Take the belt off and spin every pulley by hand:
    Alternator
    Water Pump
    Power Steering
    Idlers
    Tensioners
    AC
  5. RiCeY
    RiCeY F O R U M W A R R I O R
    Australia
    VZ SV8 6spd 6.0 470rwhp
    If you have a coolant leak and its spraying/dripping on the belt it will squeal its head off.
