Z
zzume
Guest
cikas said:I had to get the 6.0L kit for the VZ. I originaly got the 5.7L K&n Kit and it just doesnt fit. There is no attachment for the Air sensor or the other hose..
The 6.0L GTO kit goes from the throtle body to your mass air sensor , then to your heat shield then onto your pod filter.. You can see on the picture the mass air sensor is on the heat shield.. All you need to do is rotate it 180 degrees to fit onto the heat shield
ITs made a definate improvement.. The box says i gives 15hp gain but i cant back anything up because I dont have a dyno at my place
And I havent had to calibrate the CPU either.. And its been to holden and they havent said anything about it..
Hope that helps
cikas
Hey There do you happen to have the part number for the k&n kit?
Thanks.
