VZ SS ute tail light repair??
mrVH
VH wagon & 6ltr vz ss ute
Hi guys quick question, my vz ss ute's taillight has decided to lose the silver bezel around the brakelight. Its dropped to the bottom of the light assembly. Just wondering if i am able to open the light assembly and put the bezel back on? also ive got a liner, does that need to be removed to access the light assembly???
Only just got her not long ago so not sure about it, hopefully someone out there knows... anyways cheers in advance!!
Hrd455
34
Vz v6 ute
To remove tub liner remove the 4 little black screws, 2 on each side, then grab the centre outter edge and lift up
mrVH
Thanks mate
figjam
Donating Member
Far Kurnell
FJ
I have the same problem as MrVH, in that the little rings have fallen off, and the tail-lights are full of red dust.
Removing the lights is not a problem, but wondering if anyone has separated the plastic inner and outer lenses to clean/repair them. ? And, if so, did they go back together OK ?
Or should I buy a (genuine ? ) eBay set for about $90.?
Fu Manchu
WA.
Spend the $90 and go do something else with the time you save yourself.
Those parts are sealed in there when the lens is bonded to the housing.
figjam
Donating Member
Far Kurnell
FJ
Thanks Fu Man. That is what I wanted to know.
Not an urgent fix, they just look very second hand at present, something that annoys me when it get the rest of the ute clean and sparkly.
