Vz sv6 2005
Mareeanne3
55
Oatlands
VZ SV6 2005
Hi guys need help with my vz replaced fuel pump fuel filter spark plugs and coils throttle body oil pressure switch now just noticed the engine control relay is getting really hot what causes this and engine light on dash has rough idle and when you put your foot into it in mid range there’s nothing there until you put your foot into it a bit more then it takes off need help please
ant797
bunbury
vy s
If you got an android phone get a cheap bluetooth obd2 dongle off ebay and use with torque light app sometimes takes some fiddling around to get working ...or get a scan tool thats known to work on vz from a auto store could be a few things and a scan tool is an investment for future problems ...ppl will throw ideas at you like tps injectors etc and you will replace the parts and it might not work wasted money do a scan 1st
ant797
bunbury
vy s
sounds like you have a vacuum leak though
