Get it scanned professionally
You did mention no codes, how was it diagnosed?
Not every DTC activates the MIL,
And some scan tools won’t display some DTC’s,
If it cuts out without any DTC’s logged,
It’s either a power issue,
Or Vac leak,
Fuel blockage,
Fuel filter
Fiel pump connections
Ground connections, especially the ones on the engine,
Starter motor connections,
When did this start happening?
Has any work been done on the motor
Side note: (I recently replaced the start motor on my Adventra, as it had seized, being it was the original one at 265,000 k/s, and found the battery cable was loose,)
