VZ SV6/SS Bumper Removal
Surfwagon
Sydney/NSW
AMG Mercedes C63 Wagon
Will this removal be the same for my VZ Clubsport
Yes, have had my senator bar off a couple of times.
Don't forget about the 2 screws under the number plate and also check that the number plate screws aren't also drilled into the reo bar.
Charles
VF SV6
Do i need to buy the screws that attach the bumper from Holden or can i get some similar
from somewhere like Supercheap???
What size are the screws????
vz_surfin
qld
vz
hey guys just got a vz ss thunder
just wondering best exchaust for it minus exstracters
corhijasna
47
Portland Victoria
Cheers Troy!
I just took my bar off and put the bottom grill in...
Also as for the spotties there's enough length on them to sit the bar on the ground.
Also found the 2 horns behind the bumper... So it looks like I've got three of them??
the horn under the bonnet as far as I know is for the alarm if fitted or the central locking
routier1642
61
Australia
2005 Adventra LX6
I used these instructions to remove the bumper from my VZ Adventra.
It had a lot more screws, but otherwise, it was the same procedure as described.
Excellent description - thanks a lot!
BlueCrew
VZ Crewman
Thanks for posting this and thanks to your instructions I had the bumper off, headlights replaced and all back together in 15 minutes all on my Pat Malone..
Happy Days!!!
infamous2117
Parramatta
SVZ
Thanks for this, i need to replace headlight bulbs on my VZ and i may need to take the bumper off to access the headlights.
galahs
VT
You are right. On my 2006 Adventra...
7 x philips head screws on each side, 3 x 10mm bolts underneath and the 3 x philips head screws at the grill
Holden27
Wollongong
VZ Lumina & VR Wagon
Hi all, could someone tell me if a vz sv6 front bar will fit onto a vz lumina wagon front end? My lumina bar is destroyed and I have come across an sv6 bar cheap, cheers
