[VIC] VZ SV8 track car
DumpedVT
Ballarat
VT 2 Clubsport, Astra J turbo, VN Ls1,
ITEM: Vz racecar
PRICE: $15,000ono
YEAR: 2005
SERIES: vz
BADGE: sv8
ENGINE: 6.0lt l98
TRANSMISSION: turbo400 3-speed auto
COLOUR: Dark blue
EXTERIOR CONDITION: great
INTERIOR CONDITION: half stripped
WHEELS: Interceptors
ODOMETER: 6x,xxx unsure been a while since I looked at it
SERVICE HISTORY: every race event
REGO OF CAR: None
PLATES INCLUDED: No
RWC: No
PAYMENT OPTIONS: COD, Direct deposit
CONTACT DETAILS: Pm or txt 0448536386
OTHER INFO:
Well plans to buy a house are underway and I need to sell my toys to afford a house,
So first thing up is my vz sv8
Car is running a cammed l98, that produces over 320rwkw
Backed up with a turbo 400 full manual reverse pattern trans with 4000rpm convertor
And behind that is a 3.73lsd differential,
Supporting the engine is 42lb injectors, fuel cell in the boot, under car surge tank and a single 044 with adjustable regulator attached, and billet alloy fuel rails, all the undercar fuel system will go straight into any vt-vz has lines to connect to original fuel tank or cell in boot,
Internally in the engine is a double row timing chain, upgraded 1 piece pushrods, ls7 lifters, double valve springs 650" lift, upgraded rocker arms, arp head bolts, 92mm throttle body,
And onto the exhaust, 4 into 1 stainless extractors, cat delete pipes, and a catback system with no centre mufflers only rear,
Car is half stripped inside with a half cage fitted with 4 point harness's for drivers and passengers seat,
Car has run a 10.9, and runs 10.9-11.0 everyday and is a bucket load of fun!!
I'm asking $15,000 Ono
Vehicle is not registered, although I can organise a trade plate to test drive a potential buyer if required
All the gear in this car is easily transferable into any vy-vz vehicle or could be used in a project car!
