StormVz
Hi im here for info so ill get straight to the point. Ive read through the other posts and haven't yet seen this so...
I have previously had some heating problems with my 05 VZ ute that turned out to be air locks in the system. Today i gave a full service, replaced the coils and plugs and flushed the coolant system. Upon putting it back together i was topping up the system having just put the manifold back on and noticed it wasnt taking enough water, was overflowing at 5 litres. Long story short i let it get to temp thermostat opened (i thought) and filled it up. Bled the system, went for a quick lap of the block and when i removed the radiator cap the bottom of the thermostat, (the small disc with the rubber on it) was in the filler tube. I now have to pull the manifol back off to obviously replace the thermostat but am worried that other parts of the thermostat are in the cooling system. Where should i look for internal water galleries that may house the other parts, if they have broken off?
also on a side note. sometimes it will not start but just keeps cranking for 20 seconds or doesnt crank at all, the key just turns?. it always starts if you wait around 40 seconds after and try again? have had a scan tool on it and no problem apparently but my experience with it not starting would say otherwise? any ideas on that? i know this isnt the section but was just wondering.
Any info would be of great help
Thank you very much
Thank you very much
