Dimitrios
- Mar 19, 2013
- 4
- 0
- 1
- Age
- 38
- Location
- Sydney
- 2005 VZ SV6 3.6L 190kw
I have a vz sv6 5 speed auto 190kw 193,xxx Kim's
the gears seem to hold when accelerating at a normal pace the power button is off but the gears really stretch out and the third gear is quite jolty, the gears kick back faster than they should it seems I'm pretty sure the transmission is due for a service, I have only had the car for a week and am unsure if investing in a service is worth it if I need to replace the transmission all together I have also been told it may just need a reset from holden I have no idea what that means if anyone can enlighten me it also has a problem in the passenger wheel joists or baring or something that is causing the breaks abs and traction control warnings to come up I am not sure if this is playing up with the gear changes any help on this subject would be greatly appreciated as I'm clueless
( the transmission does not slip out of gear at all just the gear changes are not as smooth as they should be, sticking, kicking back)
