VZ Ute airbag error
Pezvz
59
Ulladulla
VZ ute
I have just bought my first ute ever, an '06 VZ. But I get an SRS airbag alarm every time I start it. The guy who sold it to me told me that he had replaced the instrument cluster from a VZ sedan and the alert was because it couldn't detect any rear airbags. I have read that even Holden shops can't clear the error because it's a safety thing. First question - is the missing back seats likely to be the problem? Second question - how do I fix the alarm? Third bonus question - how can I be sure the existing airbags are functional without doing a full test (ie crashing the car)?
Thanks
Fu Manchu
WA.
The cluster is easily reflashed to be set up to the ute. Envyous Customs do it. They are forum sponsors and have a section in the forum front page.you can also go to their webpage for more info.
Fu Manchu
WA.
In relation to the airbags, check the fuses for continuity with a multimeter. Disconnect the battery first.
Pezvz
59
Ulladulla
VZ ute
Thanks Fu Manchu, I will check them out.
Fu Manchu
WA.
Thanks
As for the airbags being tested, this can be done by using a GM Tech 2 connected to the cars OBD port under the steering wheel.
That is done by a garage or Holden.
Lets do the basic stuff first.
1. Check fuses
2. Get the cluster correctly set up to the vehicle.
3. Use a Tech2 module to further investigate any recurring faults (not just reread codes)
