VE360VE
- May 13, 2019
- 3
- 0
- 1
- Age
- 36
- Location
- Brisbane
- VZ Ute LE0
VZ Ute, pretty well ready to set it on fire. Bit of what's going on:-
Hazard lights, locking/unlocking car, left indicator keeps blowing indicator fuse. Right Indicator works fine. (Hazards also blow hazard fuse when turned on)
Leading up to this issue the following was done, ECM/BCM/PIM sent off for repair, repair completed and installed back in car, car started fine (did not test indicators or take for drive at the time). Seats pulled out for new seating cushion to be installed. Amp installed under passenger seat (silly question but does any of the loom run under the flooring directly under the passenger seat??), Amp works fine. Seats installed back into ute and that is when the issue started.
I've tired eliminating areas of the lights, disconnected towbar connector loom, rear light looms, left indicator bulb connector (Side lamp as well). Tested left indicator with new fuse, blows fuse immediately. I'm really not a electrical master and was wondering if anyone has some advice?
