Vz Ute tub length?
rudi
TASMANIA
vx executive
Hi all
I can only find a ve in a yard to measure which has 1900 inside measurement.
Anyone know?
Drawnnite
Obviously Unsensible
2000 Vs Ute
did you want the measurement at the base or higher up where it would be a practical measurement?
Can probably measure it tomorrow.
Drawnnite
2000 Vs Ute
So rough measurements but they are as follows
Keeping in mind, It has the tub liner and also the Holden Rubber mat in the back
2100 is length from front to back at the bottom (keeping in mind the tailgate does tilt forward a bit and there is that inner section behind the seats)
1800 is length up high from front to back (from where the top lip is at the front to the back)
450 (but could be 500) is the depth of the tub
1400 is the average width at the back
1150 approx the width where the wheel arches are
rudi
TASMANIA
vx executive
Thanks Drawnite
That’s exactly what I was after.
The length at the floor is good. Bit of a bugger the top is shorter but liveable thanks again
Drawnnite
2000 Vs Ute
All good.
Keep in mind the 2100 length you probably have about a 300mm height at the cab end for the first 300mm or so. before it comes up to the top.
If it also helps, the rubber mat at the cab end is folded up, so if you didn't have a tub liner you probably gain about 100mm going by the length of said mat. along with about 50mm depth and another 50mm or so width.
Should of also measured the wheel arches in height, but it is roughly 150mm high.
