vz ute window problem
Auscharlo
53
karratha
vz ss ute
Hi there, I'm sorry if this has been asked before but I have searched loads of window fault threads and cant find an answer. My friend who lives 500km away in a remote town has a vz ute, the drivers window stopped working. I took a second hand door (for parts) down the last time I went to visit him and found that the window has moved backwards as it winds down and hits the door lock inside the door. I replaced the lock as it was bent and the window reg as I thought this was the problem. It is still hitting the new lock, even with the little rubber piece in place at the end of the window trim. What stops the window moving backward as it doesn't have a full track like a normal car? I couldn't see anything missing, bent or broken and would like to make sure I take the correct part next time I go to visit him. Any help would be much appreciated
Fu Manchu
WA.
Are the plastic guides worn? Maybe then, the window can move around in the runner.
Auscharlo
53
karratha
vz ss ute
I couldn't see any guides in either door, I presume it is a fault in the front of the window because it is moving backwards
Fu Manchu
WA.
Here’s a screen shot of some aftermarket new ones. I circled the guides.
Auscharlo
53
karratha
vz ss ute
Thanks for that but I'm sure that its not the problem as I changed the complete regulator with no difference, I even adjusted the slider on the door to try and tilt the window forward. On the rear of the window there is a metal slider and I'm wondering if there is something similar on the front of the window?
99notout
VZ Equip Wagon
Here you go, this should help and let you see what you are dealing with.
  • Window guides etc.pdf
