J4K3W1114M
- Sep 6, 2021
- 4
- 0
- 1
- Age
- 24
- Location
- mount gambier australia
- commodore
Gday guys.
i have a 2005 VZ high output SV6 factory manual and the body is defected and pretty smashed up. so i brought a 2004 VZ high output SV6 factory auto and i’ve pulled the motor and gearbox out of both cars and put all the manual bits in the auto shell.
so i’m running the factory manual high output motor with the manual engine loom and manual gearbox loom.
now i’ve put the manual ecu bcm pim and key in the auto shell and had no injectors pulse no fuel pump prime no crank, nothing.
i put the auto ecu bcm key and pim back in with out the TCM (manual loom doesn’t require a TCM) and i have injector pulse and the fuel pump primes but still no crank. bridge the starter fuse and it will start and runs and drives but obviously doesn’t run properly because it’s auto tune not manual.
i know the computers are linked to the vin, but if i’m using the manual computers essentially it’s the manual car electronically in the auto shell so why won’t it run?
would the cars having different abs modules be my problem?
the auto shells abs has less abs lines then the manual shells abs has.
not sure where to go from this point. i’m pretty stumped, so any help or advise would be muchly appreciated.
thanks in advance for any help
