VZ V6 Manifold Torque Settings
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by Growley, Jan 22, 2015.
  1. Growley
    Growley New Member
    NSW
    VX
    Hopefully an easy one. I've changed the spark plugs & inlet manifold gasket now I just need to tighten the inlet manifold bolts. I've found these settings in an old thread. Can someone confirm or advise the correct settings pls.
    UPPER INLET MANIFOLD
    ATTACHING BOLT
    TORQUE SPECIFICATION
    10 - 14 Nm
    >>> Haynes and gregorys have the upper intake for 23 nm
  2. exanVZ
    exanVZ Active Member
    VZ Thunder
    my gregorys vz book says (for 3.6L) intake manifold 23nm, spark plugs are 16-20nm.
    hope that helps.
    Fu Manchu likes this.
  3. 99notout
    99notout Active Member
    VZ Equip Wagon
    23.0 Nm in the genuine manual.
  4. Growley
    Growley New Member
    NSW
    VX
    Thanks guys. 23.0 it is then... :yeah:
  5. 99notout
    VZ Equip Wagon
    Main thing is always undo bolts into alloy when cold < 50 degrees c. and vice versa, and never use a rattle gun as it is easy to pull the threads out of the alloy component.
  6. exanVZ
    VZ Thunder
    Growley, random question but are you an IT guy or something, found it interesting you referred to the toqrue specs as settings. Don't mean anything by this just curious haha.
  7. Growley
    Growley New Member
    NSW
    VX
    Got me! :whistling
    I didn't even realise till you pointed it out...
  8. exanVZ
    VZ Thunder
    Me too, that's why I picked up on it, haha. :)
  9. JohannesM
    JohannesM New Member
    VZ 2004 Station Wagon 6Cyl Ecotech Luminaire
    Hi, I have snapped one of the longer front bolt and would like to know if anyone has any spare one of these.
    I have not removed the manifold yet as it all seems to work fine so. But when I do remove it I will need to find out how far down its broken and attempt to remove the remaining part. Any idea on the size/lenght/tread type of this bolt would also help.
    HAS ANY ONE ELSE SNAPPED THE FRONT BOLT, IF SO HOW DID U REMOVED THE BROKEN PART?? TX
  10. robgm
    robgm New Member
    VZ Acclaim 2005
    Actually, 23nm feels not that tight.. might need to use thread lock. I overtightened and then put my torque wrench on it and realised I tightened too much.
  11. shane_3800
    shane_3800 Active Member
    places
    vr commo
    Mate I just go untill they feel tight. probably around 30-35nm going off my well tuned click elbow.
    I just did an ecotec today which are 15nm lower and 18nm upper I did use my torque wrench (snap-on digital) but it's not crucial. I use my torque wrench as a guide on what feels right. It's all in the feel.
    On the same engine I did the rocker pedestal bolts upto 15nm then set the wrench to 30nm and looked at the swing and got about 45-50deg so went to 33nm and got an extra 5-10deg and felt them go into yeild. new bolt setting is 15nm plus 90deg which should come to about 30-35nm on that size bolt.
  12. robgm
    robgm New Member
    VZ Acclaim 2005
    Any issue if overtighten except stripped threads? I guess for the inlet manifold it might be possible damage that metal gasket or maybe not since its metal?
  13. Trevor loves holden.
    Trevor loves holden. Well-Known Member
    vs commodore
    Book says 12-18nm for intake attachment bolts, fuel rail and top intake 10-14nm, air intake chamber the same 10-14nm, any think more will bugger the gasket and thread.
    My bad that's VT, VZ VE 25nm.
  14. Fu Manchu
    Fu Manchu Well-Known Member
    WA
    Slug powered VZ, a VE Calais & your mum.
    Distorting the manifold would be possible. That would lead to tiny hard to find/fix vacuum leaks.
  15. Fu Manchu
    WA
    Factory torque spec is 23Nm.
