vz v6 throttle body
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by ThunderKid, Mar 27, 2011.
  1. ThunderKid
    ThunderKid Not enough hours in a day
    Innisfail
    VZ Thunder S
    in the next week or so ill be pulling off my vz v6 TB and will be putting a few ideas to work.
    i wish to try to bore/hone it out and fit a bigger butterfly (also do the same with the manifold)
    or if that fails i will attempt to make a custom made one with a old/damaged TB and some materials.
    any tips or advice or anything anyone wishes to advise?
    if sucsesfull may even consider making a few extra that ill sell.
    ill update with photos and info if goes to plan
  2. richardpalinkas
    richardpalinkas Blown Alloytec
    Gold Coast
    Raptor Impulse VZ SV6
    someone on here has already done that. but good luck with it
  3. VZ_commo91
    VZ_commo91 New Member
    Ipswich QLD :(
    2006 VZ commodore Acclaim
    Yeah I'm sure I read some polished it, and it didn't work, it just ended up getting error warnings on the dash...
  4. richardpalinkas
    Gold Coast
    theres also someone on here who bored it out to 74mm, from 68mm which i think is the standard size
  5. ThunderKid
    Innisfail
    VZ Thunder S
    yeah after i knife edged the butterfly it came up with powertrain error but it was because of one of the following what i did:
    1. opened the sealed unit to have a look and to hold butterfly open.
    2. mightve removed throttle wire while key was turned on notch
    it does go away after a few drives unless you really did stuff something.
  6. impulsive
    impulsive Alloytec Racing
    Brisbane, QLD
    VZ Alloytec
    impulsesv6 'bored' one out, i trialled it on my car and it made some minor differences with a modified manifold, dont think it would do much on a standard manifold.. if your interested in having yours done pm me and ill see if i can help you out
  7. ThunderKid
    Innisfail
    VZ Thunder S
    just messaged you mate.
    sence there has been alot of action with modified tb's what about any custom made ones?
    my idea is to make it out of mild steel at this point so i can do it all myself to trial it and then go alluminium.
    and as for the electronics id get a doner and chop the pipe section off and mount the rest onto the new bigger pipe section.
    ideas?
  8. CRUSTIN
    CRUSTIN P-plater
    VZ S 175 Ute
    Unless you have done a tune, exhaust, cams, intake, manifold, port and polish. There is no way boring your TB will do anything.
    The restriction from the TB will be next to nothing.
  9. richardpalinkas
    Gold Coast
    very true, phil from performance manifolds has said he has gotten alot of power out of the standard tb
  10. heyitsEnricoPallazzo
    heyitsEnricoPallazzo Big block Alloytec
    VZ A4 Saloon
    Don't VE's have a larger TB? Will they fit?
  11. richardpalinkas
    Gold Coast
    ve will not fit, different connections as far as i know
  12. ThunderKid
    Innisfail
    VZ Thunder S
    ok thanks for that guys, yeah i have a good few mods and im leaving a tune for when i have done everything so i dont have to keep getting one after each mod.
    think i may just have to settle with what i have in the tb section if there is only very little gains.
    my diff gears should be ariving soon anyway so ill have something to do :)
    i dont think there is much else to add to this thread but i appriciate the info and imput.
    thread close.
  13. CRUSTIN
    CRUSTIN P-plater
    VZ S 175 Ute
    A mate of mine from work hat a cagiva raptor 1000. He put new pistons in, higher compression, and cams. Power was up from 110hp to 160hp.
    At that rate, his standard intake box was becoming restrictive, he gained 20hp from drilling more holes in his intake box.
    My dad has a cagiva xtra raptor 1000, same engine, but if he drilled the same holes, it would do almost nothing, because the intake is sufficient for the airflow from the standard engine. Same with the TB, unless you are generating more flow than standard, there is no point changing the TB. Besides, there is more of a restriction from the intake tube than the TB. Take away the biggest restriction first, standard filter, intake box, exhaust, intake manifold, cams. Then, maybe TB.
  14. wish_i_had_an_8
    wish_i_had_an_8 New Member
    Pakenham, Vic
    vz calais
    i am in the process of boring out 72 and 74mm tb's atm and will be doing a before and after power run on my car, it is supercharged so the power gain might not be the same for n/a cars but i have a friend lined up to do a power run on a standard motor and see what gains are achived (if any)
  15. CRUSTIN
    CRUSTIN P-plater
    VZ S 175 Ute
    If its supercharged, you will either notice no difference, or your feeling a placebo because of all the time you spent on that tb for nothing.
    And if its factory supercharged, have you put on an overdrive pully? Cause that makes far more sense than making useless mods that might in theory give 0.5% more power.
  16. richardpalinkas
    Gold Coast
    vz dont come factory supercharged, thought id point that out :)
  17. CRUSTIN
    CRUSTIN P-plater
    VZ S 175 Ute
    Yea thought so, came across my mind cause the ecotec's had one.
  18. wish_i_had_an_8
    Pakenham, Vic
    vz calais
    CRUSTIN this Thread was started for vz throttlebody's if you dont like the idea of them then why are you reading about it?? no my cars not factory supercharged because they dont make a factory supercharged vz, and they dont make an overdrive pully for vz's eather (for obvious reasons) there is not much more i can do performance wise and the most restrictive part of a vz's intake system (well one wich has an aftermarket intake) is the throttlebody and inlet to the manifold.
    my opinion is dont comment on things you have no idea about, go back to the ecotec forums
  19. VZ_commo91
    Ipswich QLD :(
    Thought I might point out there is an underdriven pully for the VZ.
    also, ease up. ####. No need to go off the deep end for a small mistake.
  20. wish_i_had_an_8
    Pakenham, Vic
    vz calais
    Sorry this guy is just a colossal pest. and i know they make underdrivenpulleys for vz alloytecs, i actuly have one, but they dont make overdriven pullys
