Interference design.As a point of interest, is the Alloytech a non-interference engine? These pictures are terrible by the way. Did the VE survive?
SabathSS can't believe those photo's ay... I guess that's what happens when you leave an oil change for 45,000km's+ !!!
never buy a company car or one with a poor service history or no historyIn my opinion the oils used are adding to the sluge problem because of additives in the oil. I would not use a Valvoline oil even if I got a tanker load for nothing.
Use Castrol Modern engine and change the oil and filter every 6000 k works out about the same as the dearer oil with 10 000 k change but is cleaner for the engine .
I would flush it with 50% Kero and engine oil a few times and put in a new oil filter each time . Drive it slowly around the block each time. Then when the oil filter stays clean . Then new oil and filter and see how she goes for a while and if ok new oil again in a few weeks . Then every 6000 k.
Some service people charge you for top expensive oils but put in crap oil instead . I have seen situations where the oil was not changed at all.
If I am paying for a service I put a nail polish seal on the sump plug although some wise asses just crack the plug and retighten and I sample the oil after . Mostly I do my own .
Also if you get oil into the cooling system after it is fixed run Kero as coolant for a while to absorb and strip the oil , then water to strip the kero then normal coolant .
