Sean880
- May 14, 2009
- 1,191
- 193
- 63
- Location
- VIC / NSW
- 2012 VE SV6 ser 2 and 911 Porsche Carrera S 997
I guess what I was trying to go for is it it all falls to pieces what are my options to move forward with.
I will have a look into lodging a claim through ACCC any experience with this, timeline to get it though??
There is no point in running off to the ACCC until you have lodged a formal warranty claim with Walkinshaw and you have a response from them. If you are going to go down that path then do it thoroughly.
You have such an expensive and major issue with the car that you should use a lawyer to file a well constructed written warranty claim with Walkinshaw.
1. If your car is still covered by the Walkinshaw voluntary warranty (which only applies as long as the Holden factory warranty is still valid) then you claim under that with a further concurrent claim on Walkinshaw under Australian Consumer law.
2. If the voluntary Walkinshaw warranty has expired on your car then your warranty claim on Walkinshaw needs to be submitted under Australian Consumer Law.
If you make a warranty claim on Walkinshaw I would suspect they will be defensive so be prepared for that and they will almost certainly want to inspect the car.
(You cannot realistically sustain a claim on Holden given the very significant modifications to the car made by Walkinshaw which substantially changed the product from the original specs unless you could convincingly demonstrate that the failure could not have been caused by any modifications performed by Walkinshaw but by a fault attributable solely to Holden's original product).
http://www.walkinshawperformance.com.au/W-Series/W457/
Walkinshaw 457 Kit...
"Package Contents
- ► WP230 Supercharger Package
- ► Large high flow injectors
- ► Eaton Twin Vortices 2300 Series (TVS) Gen VI rotors
- ► Water to air intercooler package
- ► Custom moulded heater hoses
- ► Cast aluminium coil covers
- ► Full dyno tune from an authorised Walkinshaw Performance Centre
- ► Unique Walkinshaw Performance roto-moulded cold air intake package
- ► Heavy duty serpentine belt drive system utilizing Goodyear ‘Gatorback’ belt
- ► 12” long intake runners
- ► Custom moulded intercooler hoses
- ► Self-contained oil system
- ► Walkinshaw Performance Ceramic Coated Headers
- ► Walkinshaw Performance Dual Active Cat Back Exhaust
- ► Walkinshaw Performance Cold Air Intake
- ► Walkinshaw Performance ECU Calibration
- ► W457/497 Badging
- ► W Series Certificate of Authenticity
- ► Walkinshaw Performance Drive Line Warranty
