Wagon Smart Shade
Defected
Pakenham, Vic
VF SSV Redline S1 Wagon
Recently picked up a set of genuine smart shades as I have a little one in the back, I cannot for the life of me get the shades to seat properly in the window as it will either shimmy up when I put the window up or pop out whilst putting the window down.
What am I doing wrong, anyone have them installed?
tml678
2017 HSV30 Senator, 2000 Magna
Yes, I had them on my VFII CalaisV wagon, and you're right, they are an absolute nightmare to fit, those little metal clips just don't want to sit right. From memory, it was a matter of spacing them correctly I think. But even then, the shades never sat completely right. Normally genuine accessories fit like a glove, but these are a frigging debacle. Good luck..
Defected
Pakenham, Vic
Ah fantastic, from memory were the clips spaced wide or narrow?
tml678
I'm pretty sure I had them narrower than the pics on the instructions, but to be honest I'm not 100% sorry mate. From memory there also didn't seem to be enough stability in them to hold the shades properly once they (the clips) were under the window rubber. I do have a strong recollection of fitting them through the windows from the outside of the car if that helps..
On the flip side, I got them in eventually, (even though they didn't sit as tight/flush as I would have liked), and they didn't move for the remaining 12 or so months I had it, so it can be done. Keep us posted :)
TSMAX
HSV CLUBSPORT R8
I have them on my clubsport for the last 18 months, got them in easy. Space the clips around 15-16 inches apart.
I can open and close the windows as well without any issues. Are they genuine holden? I bought some aftermarket ones for my wife's car X-Trail) and they are lying around since then as they require to stick the clips to the trim with 3m tape which I didn't want to do. Genuine's should fit easy.
tml678
Sedan or tourer?
Mine were genuine and it was a prick of a job.
TSMAX
HSV CLUBSPORT R8
Sedan or tourer?
Sedan, mine were very straightforward honestly, took me a total of 10 mins both sides max.
The clips slip into the rubber lining at the top and clip onto the shades.
tml678
Wagons must be different, both myself and the OP and two other people I know have had dramas with them.
They are a different shape to the sedan windows which may have something to do with it.
TSMAX
HSV CLUBSPORT R8
Yeah wagons are different shape slightly, that might be the issue.
abuch47
Madelaide
LSS3 YOOTE
I had the similar issues with the window visors.
got the genuine ute ones and all spent ages setting it out perfectly, clips would not work at all and possible lodge into the glass so I canned them. 3m tape they give you is plenty.
