WARNING LS3 Recall about to happen
Discussion in 'VF Holden Commodore (2013 - 2017)' started by GMVPSS, Dec 1, 2017.
  1. Over 60
    Over 60 Member
    Director
    If you look at the previous link from sequal 3rd feb, their instructions to dealers look pretty simple to me. You just need a tool to get 2 screws out, rubber grease and a seal.
    SSV 407 likes this.
  2. Over 60
    Over 60 Member
    Director
  3. SSV 407
    SSV 407 Active Member
    VF II SSV Redline
    Thanks Over 60. Must have missed that post :confused:
  4. Skylarking
    Skylarking Well-Known Member
    Downunder
    Commodore Motorsport
    By clicking on the service bulleting i linked a few posts up, look at what is involved and you should be able to decide yourself if the job is within your skill set ;)
    What's great about having access to service bulletins and recall notices containing real technical information is that owners can understand what is being done and thus ensure the dealer is doing the job correctly. Sadly the crap recall notices we have on the ACCC site are deviod of real technical information and service bulletins are unavailable within the australian market :mad:
    PS: ninja'd by @SSV 407
    SSV 407, Over 60 and SSteve like this.
  5. SSV 407
    VF II SSV Redline
    Any chance you know where to buy a slim ratcheting driver that's required?
    I had a Thousands of $$$ in tools...everything except that o_O
    PS. Sequal. Thank you for the PDF ;)
    sequal likes this.
  6. Skylarking
    Downunder
    The Service Bulletin indicates a small ratchet with a cut down phillips hex bit can be used until a specific tool is provided by Holden.
    By all means, purchase such a limited use tool or simply look through your $$$ in tools for something you can MacGyver up ;)
    Heck, a cut down phillips hex bit with a washer welded half way up the bit and drop into a small ring spanner should do the job :cool:
  7. Skylarking
    Downunder
    @sequal just wondering how you went with the HVAC drain seal fixed and did the dealer/holden clean up all the mold and/or replace the carpets ?
  8. phantom0817
    phantom0817 New Member
    SS
    I received no letter at all but when I rang the service dept they were happy enough to have the lifters and Hvac done, which supposedly has been done now. I hope they would have suggested to do it at the next service but odd that no letter was sent, let alone the free service offered to others.
  9. lmoengnr
    lmoengnr Well-Known Member
    Sunbury Vic.
    MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
    Something like these? A mate found these in the US and bought 10 sets back, 2 for me.
    SSV 407 likes this.
  10. Anthony121
    Anthony121 Well-Known Member
    VF SSV Redline MY17 & VF Director
  11. SSV 407
    VF II SSV Redline
    I like your way of thinking ;)
  12. DIR-ACT
    DIR-ACT Member
    ACT
    Director - about September
    Rockers and A/C grommet replaced today. Now to do some driving and get a few more kilometres on it. Happy Days!
    SSteve likes this.
  13. sequal
    sequal Member
    VFII SSV
    It took a week to get it in to a dealer, and I called around all in the area, but it is all sorted. The seal is fixed and the carpet replaced.
    After looking closely at it, it was much worse than it seemed.
    VT2Commie, SSteve and revster like this.
  14. Over 60
    Over 60 Member
    Director
    Just on another issue, I have never had high performance 20 inch RE050A tyres before. Do they sound a bit like a bearing noise or should I get that looked too.
  15. KT11H
    KT11H Active Member
    VFII SSV Redline Ute
    20" RE050A on my ute are rather noisy too, there are also some humming noise with the tyre slapping on the road. I doubt that they are bearing noise which will be very noticeable and so far there isn't any complaints from members on the VF2's wheel bearings. No harm to have yours looked at by the dealer.
    Over 60 likes this.
  16. Over 60
    Over 60 Member
    Director
    Thanks it's probably tyre noise then. I'll get it looked at service
  17. saroadie
    saroadie Active Member
    2015 VF SV6 Storm
    Yeah that's normal road noise for these.
    Over 60 likes this.
  18. Over 60
    Over 60 Member
    Director
    Thanks
  19. vc commodore
    vc commodore Well-Known Member
    south australia
    vc commodore
    You can check if it is the tyres yourself.....Jack the front corner of the car up and spin the wheel, with your ear near the centre of the rim....If you hear a rumbling noise, the wheel bearing is gone....If you don't, it's the tyres
    426Cuda and Over 60 like this.
  20. Over 60
    Over 60 Member
    Director
    Took your advice and jacked it up. No bearing noise only slight rubbing of brake pad noise. Must just be the tyres. Thanks
    GMVPSS likes this.
