washing a ute
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by evil_monkey, Apr 20, 2006.
  1. evil_monkey
    evil_monkey New Member
    Australia
    Holden
    :embarrass excuse my stupidity but im used to washing sedans :p
    i was just wondering you guys with utes how do you wash it in regards to do you take the tarp off to wash it or do you leave it on :confused: i take my cars to the car wash and use the high pressure hoses last time i washed it was annoying because the tarp holds a bit of water and for ages keeps dripping over the side of the car also the tarp is very dusty the hoses and brush didnt clean it to well, do you guys treat the tarp to prevent it from cracking in the sun ?? any tips would be much appreciated thanks guys
  2. VZGEN4
    VZGEN4 New Member
    VZ SS THUNDER
    Invest in a hard top!
  3. Struma
    Struma Urge Surfer
    VS S2 Executive Ute
    Washing the Ute
    If you are going to hang onto the soft cover - which is a great idea if you want your ute to actually be functional - I would reccomend removing your cover before you go to the wash salon.
    Wash the tonneau cover on your lawn/ driveway if you need to; give it some seperate treatment, as it is vinyl and has different requirements to your bodywork with regards to cleaning.
    The body well has holes that let it drain - check that these are clear - also let the tail gate down when you are washing so that you can get into the hinge asembly and the seal area at the bottom of the gate; an area that is prone to rust so keep these parts clean and dry off afterwards if you can.
    How did you go with your dash replacement? I have the same stock options as you and wish to perform the same mods; I would be interested in any singularities you may have encountered...
    Love my ute.
  4. bns-sticky
    bns-sticky Guest
    I got a soft torno and I leave it on most of the time.
    I only wash the tray when it gets really dirty. It should not let too much crap in there if it is a good one. Your torno must be a povo one if it doesn't hold tight enough for the water to run off. I have no probs with mine. The drain hole block easy to cos its just flewy condute and all the **** catches on the way through. Use a good vinyl treatment and you wont have any hassles. I treat my every now and then and its still like new.
    BTW I am in the process of getting the bit for a level 1 dash change upto a level 3 dash in my ute with the statesman dash surround. A HOW TO will be posted with pics when I get around to it.
  5. evil_monkey
    Australia
    Holden
    yeah i also noticed that the rear of the cover sucks down when im driving on the freeway ive been told thats normal ??? thanks for the tip struma in regards to washing the car/tarp
    the cluster was fairly easy but as it is a colum shift it dosent have tilt steering wheel so its a bit tricky to pull the fascia off you need to pull the steering wheel surround off and the colum shift selector to get the fascia and cluster off
  6. bns-sticky
    bns-sticky Guest
    Thats normal for the torno to do that
  7. evil_monkey
    Australia
    Holden
    how come i see heaps of other utes not doing it :(
  8. Struma
    Struma Urge Surfer
    VS S2 Executive Ute
    Tight Tonneaus
    This is probably a dumb question - but do you have your steel tonneau bow in place?
    Mine doesn't oscillate beyond what I'd consider normal; and it doesn't collect water to speak of either.
    It is quite worn and has been resewn once, but is still tight.
    I find that if I wash my (white) ute with the tonneau in place lots of grit and colour will continue to bleed off the cover and elastic onto my nice shiny white (bump strip free) flanks, especially since some previous owner/idiot used tyre black or something to darken the cover and elastic up before selling it. Plus I like to lift the woven matt and blast the well out occasionally. Being in Brisbane means there is always a chance of water collecting somewhere, so I am always carefull about getting all the water out of doors and body cavities where possible.
    Cheers,
  9. evil_monkey
    Australia
    Holden
    yes i do have the steel bow in place have you removed yours ?
  10. evil_monkey
    Australia
    Holden
    wait that was a stupid question.... :hit:
  11. nsladden
    nsladden GET UTED
    Murwillumbah
    1992 Holden VP Ute S 5.0L & 1989 Holden VN 5sp Wag
    I wash mine with the tonneau cover on, then i chamios it, then remove it & spray it with armour all protectant.
  12. ringfeder3
    ringfeder3 Active Member
    Nsw
    2017 colorado, 94 VR Calais, suzuki gsx1400
    Don't use those commercial carwash places...I found that the mudflaps etc all go a grey colour and the different treatments leave staining on the paint. I've been told they use a bleach type of agent to cut through road grime... Yuk-off cleans the tonneau really well without attracting dust. Good for interior as well....
