[VT-VX] Water Leak Between Engine & Gear Box
U can Fix it
Australia
vt v6 Berlina & SLR Torana & Holden Rodeo
If you have an over heating problem or a oil leak between your engine and Gear Box you will find you may have to replace the rear main seal and plate, this job can be done by one person. I made a Video with a quick overview.
how to fix a over heating issue on a Holden commodore, Berlina, Calais ect... water loss between engine and gear box, rear main seal and plate.
1. Remove exhaust
2. Remove Tail shaft
3. remove Gear Box
4. Remove rear main plate
5. clean gasket from block
Now install New Plate/Gasket seal
Reinstall Gear Box, Tail Shaft & Exhaust :)
VS VT VX VY COMMODORE ACCLAIM BERLINA CALAIS S ETC HSV XU6, VS WH WK STATESMAN CAPRICE V6 3.8L
COMMODORE 3.8L REAR MAIN SEAL PLATE ASSEMBLY
THE COMMODORES HAVE A COMMON LEAK WITH THE REAR MAIN SEALS, FIX YOUR LEAK, REAR MAIN PLATE ASSEMBLY Cost : around $160
Always Be Safe When Working Under any Vehicle and make sure it is well supported and secure
The Lion
55
townsville
HZ TONNER ,C1500 Chevy , VX DAILY DRIVER
Would a radiator block treatment work if its small ?
