Water Leak...
accentstencil
69
Eschol Park, Sydney
WH II Caprice, 5.7 2018 Equinox LTZ V
You should be able to tell from the water on the ground whether it is from the cooling system or not, unless you have clean water in the radiator.
jared_vn
VN exec S1
The other day i took off from the lights next to a mate and gave it a fair bit. about a minute later the car started to get really hot and there was a big line of water on the ground. Turned out the hose that comes out of the left side of the water pump and runs under the steering pump had worked its self loose and slid out a little bit. I just pushed it back in and tightened the nut on the bracket and haven't seen a drop since. could be a possibilty.
VPplayer
Melbourne, bayswater
VP Exec
I just came back from Bersons. I got some new hoses, ill put them on when it stops raining. im corssing my fingers that its just the hoses
