It’s a stupid design to be sure. I’ve had plenty of cars in the past that had no door card plastic at all and never had a problem with water leaking in. My SSV was full of water just from having the bottom of the plastic unsealed for about a foot or so. When you hose the outside of the door tonnes of water pours up against the plastic.I think there will be a lot more VE owners plugging up their leaks after this. I've been chasing the train for at rear carpet recently too. Pulled off all the bottom for seafood and cleaned them, and removed drivers door skin to check how much dirt was in the bottom and cleaned it out with a paint brush. What's a good product to use to re seal the plastic lining? Seems kinda strange that the door innards would be designed to direct the water to run down the inside face of the doors? That will always lead to leaks at some stage. Surely some wise old elf in the design team would design team would make sure there was a deflector or something inside the door that keeps train taking towards the outside door skin? An I the only one that thinks that way.?
Also if you’ve got water in your rear carpet check your front door cards! My rear carpet was soaked and the front carpet was mostly fine. My rear doors weren’t leaking it all, it was from both the front doors.I think there will be a lot more VE owners plugging up their leaks after this. I've been chasing the train for at rear carpet recently too. Pulled off all the bottom for seafood and cleaned them, and removed drivers door skin to check how much dirt was in the bottom and cleaned it out with a paint brush. What's a good product to use to re seal the plastic lining? Seems kinda strange that the door innards would be designed to direct the water to run down the inside face of the doors? That will always lead to leaks at some stage. Surely some wise old elf in the design team would design team would make sure there was a deflector or something inside the door that keeps train taking towards the outside door skin? An I the only one that thinks that way.?
Same here, always parked nose up. The biggest problem I've got with that is it's impossible to check the oil level at home!Also if you’ve got water in your rear carpet check your front door cards! My rear carpet was soaked and the front carpet was mostly fine. My rear doors weren’t leaking it all, it was from both the front doors.
If your car is parked even slightly nose up (as mine is when it’s in the driveway) all the water will run down the side channels under the carpet where the wiring looms go to puddle at the back of the car.
Ooh the Butyl tape looks like good stuff. For a second I couldn't seem to find the length of tape in each pack. Thinking why don't 4M label their blasted adds properly, and since when did 3M aquire the 4th?The Sika 227 is a curing sealant. You can use it but only once. The idea of the butyl used on most cars is the plastic can be removed and easily resealed for servicing components without tearing the plastic weather sheet.
If the 227 or even a silicone is used, the weather sheet tears. You also then have to reseal, but you’ll have sealant everywhere. That needs removing otherwise you get a build up of it.
The amount of times I’ve done work inside a car door and then needed to go back in to make an adjustment is a lot. With a wet curing sealant, that’s going to go everywhere when the weather sheet is pulled back again potentially getting all over you, our clothes, the window tint, interior panels.
As I have mentioned, weather sheets are on just about every car. High end as well. (Have seen them on stereo videos on BMWs and a Ferrari)
Ones I have worked on, My old Suburus, Toyotas, every Commodore I’ve worked on has had them. Mazdas have them. Hyundais have them. Hondas too.
Usually the problem is people and mechanics impulsively peeling them back, ripping them, cutting them to get to a door lock, not using general care and putting them back on damaged (or not at all). Then water gets in.
The Car Builders Door Restore kit:
https://www.carbuilders.com.au/door-restore-kit
Best bit is a thicker more durable plastic is used.
If someone wants reuse the plastic, or use some of their own more robust plastic then the butyl strip is easily sourced:
https://www.ebay.com.au/itm/3739580...VTSobbORpi&var=&widget_ver=artemis&media=COPY
Yes fully agree and manufacturers should hold their heads in shameIt’s a stupid design to be sure. I’ve had plenty of cars in the past that had no door card plastic at all and never had a problem with water leaking in.
Yes every car has them but the VE seems to piss tonnes of water up against the plastic sheeting for some reason.Ones I have worked on, My old Suburus, Toyotas, every Commodore I’ve worked on has had them. Mazdas have them. Hyundais have them. Hondas too.
